good points rd but. .
Aren't turbos hard to judge untill you run one with your setup?
I been posting tring to find a good combo to make around 400 with no wire tap
some say htbg some htb2 some even say don't do the b1-2 get the full b1
I think a hybrid would be good but see many in the classafieds too
I don't tow (as in big heavy stuff over 2000lbs) and am in low alltitude but do Want a wheel that spools realatively fast 18-21yet will cool ok with don's 4s to get me in that 400 range
BIG QUESTION RD: Can one buy a big charger like a full b1 and then change the ex housing to make it spool quicker an if so what is the difference in rpms heat and cfm , Explain the effects of bigger Vs smaller housings
Is it like >b1 16" then b1 14" then b1 12" then b1-2 16" then b1-2 14" ... and so fourth from great to small or what
I was surprized when I got gauges hooked up that on the rare occasion that the 35 does fully spool with street driving and cruising , only 20 on stock elbow that 20only came at 22-23 that seems late to me (even with my 4. 10 rears) for all the whisling it does from 16 up under load
So what to do if I get the full b1 its not gona spool till later and With my low rpm lugging around town 16-22 I might not ever hear it spool
My point is that Im sure there are turbos out there for sale that are bad but I think that some are like new and took off cause the purchacer didn't like the power band that it made or gave up trying to get the quick spool and cool allot of fuel and go to twins.
I whent through the same thing trying to find the perfect prop for my boat, I bought the first one new and it was wayy off. then every one that saw my ad said it must of been tore up or damaged I had the same attitude that you have and I had only run it an hour. with props you bolt it on and you make a few runs you know quick if it is what you want or not.
Then again on the flip side my friendhas a prop that is polished like new and had run it over a sandbar at highspeed and twisted the blades just enough to make it run like crap and you could not tell it from a new one.
Just thinking outload guess all that protects us on a deal like this is FAMILY HONOR the next mans good word Oh well
Sorry for the double post above THANKS for all the replys
by the way how about a flow chart and some maps for some of these mid range singles please RD you are the best!
