Using 325/600 Injectors in 305/555
NV5600 Fluid capicity..came up short
???Torque Management???
maybe a burnt piston. . the combustion recess on the pistons between the 305 and the 325 engines are different slightly. the spray angle out of the 5 holes on the 325 injectors is tighter...
Lightman said:
Has anyone tried using 325/600 injectors in a 305/555 engine if so what was the results
I have heard (second hand, so I can't say for certain) of people going the other way around, and getting better results (mileage,power) with the 305 injectors in a 325 engine.
Are the injectors identical save the tips? I wonder if someone put 305 tips in a 325 injector, if it would work in the 305?
100% yes, In fact that it what I have. I bought core 05 injectors, sent them to DON M, he put 03 tips one them. Good to go.
And I have heard that you CANNOT put 05's in an 03 truck... . BUT you can put 03 tips in an 05 truck. .
Crazy... .
I would just get the bodies and have someone do the right tips...
Well then why haven't more people done it? :confused: Why would people still be waiting for don's new injectors to come out for the 04. 5 and up crowd? Just curious, I am not sure myself.
I think because just throwing an 03 style tipped injector in an 05 motor may run ok , may make power - But it is unknown if it will last. I think don is most likely making the neccesary changes to unsure that the 05 injector be of full benefit, not just an "OK" solution...
