VA and EZ Edge
Dash Light 4WD
Erratic fuel pressure?
Fueling Boxes.
Kinda like adding a four barrel carb. to a V8 that had a two barrel. Only lots more HP increase. ;)
You've probably heard of "chipping" fuel injected vehicles. The VA and EZ are boxes that have the same effect - basically, they alter the timing and fueling curves (the inputs to the computer-controlled injection pump) so that you can get more HP out of your engine. Before you ask "which is better", let me just say that each has it's proponents.
