VA Box Timeing
South Bend Con O or Fe
Who makes a good 5"
I don't think anyone's put them both on the scope. It's generally true that the EZ has more agressive timing.
Justin
Is it safe to say that a VA is less likely to cause a possible head gasket or other engine problem than running a EZ if it has less timeing advance? I have just been reading about possible problems when running a timeing box injectors and fueling box. anybody have any ideas on this. Thanks
You could get an Edge Comp and just turn the whole deal off altogether when you reach 100 hp or so. The guys at Edge say the timing advance is turned off when the box is shut off.
Brian
