VA or EZ and 275 Question
Warranty...Exhaust
No operation of intermittent wipers
How are the factory clutches holding up to the VA or EZ and 275 injectors?
A friend wants to know
  • 98 ISB,QC,5spd,2wd,3:54lsd. Stock with BD brake and Gauges!
  • 2000 Terry 305G 5th wheel
TowPro. . My personal experience with a 2001 HO 6-sp is with the VA or EZ alone the clutch was OK. Same with only the 275 injectors. However, when you combo any of the above, your clutch will start to slip. Any up-grades to this point will require a new manual clutch or auto-matic upgrades.
Do you tow anything? If you do, do you "use the power" or just take it easy?
Originally posted by CannonBall:
I have the DDStage1 injectors, VA and the Practical Solutions boost module.
The clutch is holding fine and the EGT's are in check.
I run the 275 injectors and a VA and a prctical solutions boost module on a'99 3500 5 speed with 4. 10's and tow 14,000lbs. No mercy and no clutch clipping. The power is no good if you can't use it.
A friend of mine has a '98. 5 quadcab 3500 5 speed and 3. 55 gears. He has a PE EZ box and 275 hp injectors and no slipping yet.
later
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Towpro, I have the DD1's and EZ(set on latest fueling). No Egt problems and I use the power towing. I don't jump on the power with a heavy load. Not even a thought of slippage yet.
Steve
1999 Qcab 4x4 Driftwood
Steve
