Vaccum pump leak? No problem.
Industrial Injection Turbo Users
5" muffler needed
I have a Vaccum pump oil leak and ordered the repair kit from an ebay seller ramtrans1 . Comes with a DVD or VHS as a tutorial and every seal you need to repair the Vac pump/Powersteering pump assembly from oil leaks. On the DVD he goes through rebuilding it showing the guts of the Vac pump, etc. It turns out the DVD I got crapped out 14 Mins into the presentation so I sent him an email explaining the situation, and with out hesitation, not only did he send me out a new DVD but also a VHS copy and a free starter rebuild kit with the heavy duty contacts/plunger for my trouble! Theres a lot of bad sellers on ebay but this guy showed such great cust service I figured Id pass the word along. :cool:
Signal, I got his kit about a year ago and the DVD I got did the same thing in my laptop. It did play fine on my kid's PS2 gameplayer. If you haven't done the job already, make sure the seal surface on the steering pump hub is in good shape. The old seal will sometimes cut a groove in the hub that will ruin the new seal in short order. Mine had a slight groove that I tried to clean up but it has started to leak again after about 15,000 miles.
Sam
