Sorry if I mess this up, first time posting. Own a 95' 2500 4wd regular cab with 47rh. A while back my ps/pb started to go on vacation, I would understand this if I had a hydroboost set up but my truck still uses the vacuum boost system. Currently I am cruising around with manual steering and brakes, the wierd thing is the pump is not groaning or growling at all. The only conclusion I can come up with is from what I've read, the vacuum pump and powersteering are not turning, is there a quick way to check this and is there anything else that would cause both systems to fail on this truck.
Thanks for any and all input.
