Aux Vacuum Tank
I made and installed an Aux. tank and it seems to work OK. It is made out of schedule 40 plastic pipe six inches in diameter by about 18 inches long with two end caps glued on. I tapped the end cap for a barbed fitting for the vacuum line. The tank is carried on two angled braces bolted to existing holes in the left frame rail under the driver's door. The new vacuum line runs forward along the frame rail to the OEM vacuum line going to the brake assist where I inserted a "T" in the line.
It has been on the truck about two months and 4000 miles via mountain passes in Washington, Oregon and California with no apparent problems nor shortage of vacuum pulling a fifth wheel trailer.
