I'm trying to fix my selector switch for the a. c. vents.
I have vacuum under the hood all the way to where it goes thru the firewall by the heater hoses but I have no vacuum in the cab at any of the actuators. I pulled the glove box and could see the recirculting actuator but nothing else. When I set the switch to recirculate there is no vacuum there.
There is also none at the one by the gas pedal which should have vacuum when it is set to the panel vents. There is also none at the red hose for the defrost actuator. So I think I have no vacuum in the cab.
I had my dash half way out(the easy half) but decided there has to be an easier way. Any one know an easy way to get the dash out? Does anyone know how to get to the line coming from under the hood?
FYI - I do have air blowing out the defroster vents and the floor no matter where I put the switch. Is that what it defaults to with no vacuum?
