Originally posted by CumminsPuller
I have had about enough of my electric trailer brakes. With hotshotting it seems to be an ongoing battle with the brakes... . If that is true does anyone know ove a reliable vendor?
Jason
Without going too much into detail (I'll be glad to if you want---but remember I'm long winded
) I've done both vacuum over hydraulic, and electric over hydraulic brakes hotshotting with 2 12K AL-KO axles on a 40' flatbed.
Vacuum over hydraulic has some advantages--it's smooth proportioned braking, and you no longer worry about being able to stop with 17,000 on your trailer. On the other hand, when you're empty and catch a yellow light -- you'll put a flat spot on your trailer tires... .
I converted mine from vacuum to electric over hydraulic, and once I got the right brake controller, I love it. I use the brake smart (yeah, it's nearly 400, but still cheaper than the vacuum over hydraulic setup). I kept the disc brakes and hydraulic system from the vacuum/hydraulic, and added a Carlisle electric/hydraulic unit. If I had it to do again, I'd get the MasterBrake ElecDraulic unit, but the carlise is fine.
Now, that being said, I'm assuming you're converting from straight magnet-brakes (drums) -- so as far as I know, there's not a direct bokt-on replacement but I'm sure that Dallas Hub & Axle could tell you all about your options.
If you've got the disc-brakes, and electric activation, though, your biggest problem is most likely your brake controller.
Ack--I got long winded and tried not to. Hope this helps--and PM me for more info.
PS--Who do you hotshot for? -- I'm Acme myself.
--Chris
