Engine/Transmission (1994 - 1998) vacuum pump check valve
I have a 1997 cummins and I have the vacuum pump rebuild kit. I am getting oil in the vacuum lines so I need to change the check valve . Does anyone know the part# my dodge dealer doesn't know what I am talking about?
There was safty recall #720 it seems some of the trucks that was built before Jul 1 1996 did not have a check valve. The ones without the valve had a 14 mm fitting screwed in the pump the ones that did had a 22 mm fitting. The recall involves adding a check valve and replacing all vaccum hose's. I saw this on Geno's but can't get back to it. If your truck was built before that time check it out.
05-11-99 All Revised power brake booster check valve.
This bulletin applies to vehicles equipped with the 5. 9L Cummins diesel engine. A revised power brake booster check valve p/n 05011393AA has been released for service. The new check valve performance has been improved by changing the flapper style check valve to a spring loaded style check valve. The spring loaded style check valve performance is superior, especially in vehicles that utilize mechanical vacuum pumps to provide the vacuum source to operate the power brake booster. Part number 05011393AA should be used any time the power brake booster check valve is serviced on the subject model vehicles
