Archived vacuum pump help help
Archived Vacuum pump help help
Archived radiator drain valve
I have a 99 3500 today my power steering and brakes quit thought it was my power steering pump. My question is should my vacuum pump drive dog have play in it I found two small chuncks of metal in the vacuum pump thought they could be from where the power steering dogs were wore. but when I feel inside of the vacuum pump. I can move the impeller freely up and down should it move freely inside the vacuum pump or how does it line up. I think my vacum pump is toast. help Im at work and need to move my truck.
i had a 96 3500 and the power steering went out we put 5 ps pumps in it
before we figured out that the vac pump was bad and also replaced the steering gear box and the high pres line and low pres line
with your problem i would contact pete at gould gear 574-849-0453 cell GOULD GEAR AND ELECTRIC INC. -- email address removed -- 877-FIXINRAMS 877-349-6726
