Vacuum Pump HELP!!!
727 to gen 2 t-case info
1st gen t-case
ok, so putting the 12 valve in the 99 f-250... if i use the dodge vacuum pump where do i run the line that comes off the pump to? thanks for anybody thats can help me here...
Well behind the Master Cylinder there would be a big round disk looking canister and if its Hydro there would be 3 hoses running to it, One to the ps pump one to the steering unit and one to the ps reservoir. If its Hydro then you dont need the Cummins Vac pump.
