Looks like my gasket between my vacuum pump and the case is leaking again. (every 100,000 miles, like clockwork) Does the gasket also serve as some kind of shim? Meaning, if I don't use it, will I still have proper gear mesh? FYI- I've been racing sports cars for 10 years now. You always want to used the grey silicone for oil service parts and pieces. The orange silicone will work for a while, but then start to leak oil. The best stuff is available at the Honda dealer and it's called Hondabond. It's a grey silicone intended for oil pans, etc. There are two kinds, a squeeze tube (for applying over paper/cork gaskets) and a pressurized can for making your own gaskets. You have to follow the directions exactly. I've used it on my racing transmission (metal to metal flanges, no gaskets) and it's the only thing that worked for a whole season. It worked great on my Dana 80 cover. no leaks. A close second is the grey silicone from Loctite, but it's not as good as the Honda product. The orange silicone is best for high heat, like header gaskets.
