Help... . Dodge dealer just replaced my power steering pump under my extended warranty... Immediately started having oil leaks from around the pump... Dealer says it is the O ring between the steering pump and the vacuum pump... Neither DC nor Cummins has this O ring... They state "replace the vacuum pump"... I say BS... ... $600. 00 for a little O ring that apparently should be replaced whenever the steering pump is replaced... . Dealer even took the number from the O ring and has been unable in 48 hours to find this O ring from any seal or bearing people... Also my extended warranty does not list the vacuum pump specifically as being covered... Any suggestions???????? Should the vacuum pump be considered an "engine component"????
