Vacuum Pump Question...
Gauges installed, initial readings
won't start when hot
I'm having trouble with the brake pedal staying up when at a stop light or sign on my 92. After changing the booster I still have the problem. So I changed the vacuum line from pump to booster and when removing the line oil came out of the line.
Is there suppose to be oil in this line. The line was swelled/soft where the oil was. Need help on this issue. The master cylinder is new along with calipers and rotors. The amount of fluid in the master cylinder does not go down. Rear brakes were just serviced and no evidence of leaks.
I have used hose clamps on all lines off the booster so everything is tight.
Need some advice. Thanks in advance.
Jim
