Vacuum pump rebuild or no?
Where to get cold weather truck bra?
front sheetmetal for a 92
After searching here the last couple days I still have not found a definate yes or no on rebuilding the 1989 CTD vacuum pump. Anyone? Anyone?
Thank you all...
vacuum pump rebuild
Ditto on bgilberts reply.
I have ordered the bushings(2),pushrods(2) and gaskets from Cummins and one diaphragm was bad so I got a reman unit from NAPA for about 175 clams.
While I had it out I also replaced the "O" rings where it seals the diaphragm units to the main pump body.
Phil
I couldn't find any rebuild parts anywhere around here, so last winter I bought a NAPA reman. Using my son's discount is was around $120 if I recall correctly.
Seems to work fine. actually I think the old one was ok, but it was full of oil so I'm glad I put on the new one.
Good to hear, this will be my first of a few projects on this new to me CTD. I did get the factory manuals as well as a couple Cummins manuals, I'll never get over a factory manual compared to a chilton etc. Good stuff here on the TDR, no mistake joining and hope to learn and share if I can. Thanks to all here in the 1st Gen section for sure!
