Vacuum pump spacer
Who makes the latest greatest twins and injectors?
Fluidampr fiasco.....anyone elce ??
Does anyone know if Cummins or anyone else makes a spacer to get rid of the vacuum pump and still run the p/s pump? I am getting ready to drop a '90 into the wifes Suburban and dont need any vacuum. Thanks
Yep, all of the P30 BreadVans with 4bts have a real short adapter, then the PS pump. I used one in my 99 Ford Superduty. It worked out real well. I dont have a Cummins PN, but a search for a serial number and CPL from a 4bt out of a P30 should be able to get you a cummins PN for the spacer.
TRCM- The Chevy's dont use any vacuum to actuate the HVAC system or the cruise and since it is also hydroboost that is one more non vacuum operated system.
FordCummins- Thanks, I will research that, I thought I had seen one before.
Huh... al the chevies I have worked on did to one dregree or another... but then it has been while since I worked on a chevy... .
