Per Bush's idea, since my last power steering debacle, I decided to do a little more investigating. Bush mentioned that the coupling between the pump and vacuum was important. Well, I was gonna check both when I got home.
Never had a chance. I mentioned in the previous post that I thought I heard the steering pump going. In fact, was the vacuum pump. All of a sudden, all of the noise stopped. As did the power assist of the brakes. As did the HVAC controls.
You thought the brakes were bad when they worked, try with no assist.
So, a new pump is on the way. This time, I'm installing everything myself (will try anyway).
Can anyone help with the procedure as I don't have the cummins manual.
Thanks Bush for the heads up. And thanks in advance everyone for any ideas on pump removal.
B
B
