Engine/Transmission (1994 - 1998) Valair Clutch, whats your view
Engine/Transmission (1994 - 1998) NV4500 oil change 4or5 quarts?
Engine/Transmission (1998.5 - 2002) Throttle position sensor
ordered a valair ceramic 600hp clutch... . 1100lb-ft .....
they said it will be reall grabby with the 3800lb pressure plate, but is great or daily driving and some street performance... .
anyone have any ideas on how these react in the trucks,
hauled 15k with the stocker and all my fuel, and now it wont grabb so i had to use part of the school loan to get this one... .
Ceramic/Ceramic:
These clutches utilize ceramic buttons on both sides of the clutch disc and are aimed at the high performance trucks, these are the best of bad single disc clutches . Driving manners are very performance oriented with no clutch slip, basically the clutch is in, or it is out. Great holding capacity for highly modified trucks, the only way you will get more holding power is to go to a Dual Disc Clutch setup. Ceramic is a very hard material so typically flywheel wear is more noticeable using a ceramic clutch than with other materials. Pedal pressure is typically a little higher than factory pedal pressure depending on plate pressure(3200#, 3400#, 3800#). Drive train and Hydraulic upgrades are recommended. Some clutch rattle may be noticed while idling in neutral.
Ideally suited to trucks with high performance power modifications with 500-600HP.
(Not recommended for towing)
"Not reccomended for towing" Do you tow often?
A 3800lb plate load is a PITA in town traffic. My friend has a SBC DD 3600 and I think it is way stiff.
You get used to heavy pedal pressures. All clutches have a distinct set of characteristics that you learn to drive with/around/through.
-Scott
i tow a 4-wheeler mabe once or twice a year, a boat a lot, and only once in a blue moon a hook to 15k pounds or more... . cant say i tow very often at all...
When engaging while in a drive thru window or backing up the trailer, my valair clutch chatters very badly. Also, the truck idles/vibrates rough since the clutch was installed. This rough idle is intermittent. Sometimes when its idling rough, I will let the clutch in and out a bit while in gear with my foot on the brake and then it smooths out. All I can think is that maybe the disc is not balanced properly? I don't know. If I am idling in 1st gear there is no vibration. I did the 5600 flywheel upgrade, I ordered the one that was supposed to not need a starter spacer, but that's not the one that I received, it has the starter spacer.
