valve adjust help
Upgrade Time.....
code
2006 looking 2 adjust valves on my 59 was it in a mag? have a 97 where you turn it over backwards with alt is it the same with 24 valve? have all mags 97 till now did i miss it help please
While the following procedure doesn't tell which direction to bar the engine over, you are adjusting with crank at TDC on the compression stroke. Cam follower is on base circle and both intake and exhaust rockers are 'loose'. You only need to be close to TDC for the valvetrain to be 'loose'. There is no timing critical alignment at this point - a few degrees either way is OK. Bar the engine over in the normal direction of rotation so that accessories - like CP3 turn the right way. No telling what might be damaged by rotating in the 'backward' direction.
From 2006 DR Service Manual - Sorry, no pictures.
STANDARD PROCEDURE - VALVE LASH ADJUSTMENT AND VERIFICATION
NOTE: To obtain accurate readings, valve lash
measurements AND adjustments should only be
performed when the engine coolant temperature is
less than 60° C (140° F).
The 24-valve overhead system is a “low-maintenance”
design. Routine adjustments are no longer necessary,
however, measurement should still take place when
troubleshooting performance problems, or upon completion
of a repair that includes removal and installation
of the valve train components or injectors.
1. Disconnect battery negative cables.
2. Remove cylinder head cover (Refer to 9 - ENGINE/
CYLINDER HEAD/CYLINDER HEAD COVER(S) -
REMOVAL).
3. Using the crankshaft barring tool #7471-B, rotate crankshaft to align damper TDC mark to 12:00 o'clock position.
a. If both number one cylinder rocker levers are loose, continue to next step.
b. If both number one cylinder rocker levers are not loose, rotate crankshaft 360 degrees.
4. With the engine in this position, valve lash can be measured at the following rocker arms: INTAKE 1-2-4 /
EXHAUST 1-3-5. Measure the valve lash by inserting a feeler gauge between the rocker arm socket and crosshead.
Refer to VALVE LASH LIMIT CHART for the correct specifications. If the measurement falls within the
limits, adjustment/resetting is not necessary. If measurement finds the lash outside of the limits, adjustment/
resetting is required.
INTAKE EXHAUST
0. 152 mm ( 0. 006 in. ) MIN. 0. 533 mm (0. 021 in. ) MIN.
0. 381 mm (0. 015 in. ) MAX. 0. 863 mm (0. 034 in. ) MAX.
NOTE:
If measured valve lash falls within these specifications, no adjustment/reset is necessary. Engine operation within
these ranges has no adverse affect on performance, emissions, fuel economy or level of engine noise.
5. If adjustment/resetting is required, loosen the lock
nut on rocker arms and turn the adjusting screw
until the desired lash is obtained:
² INTAKE 0. 254 mm (0. 010 in. )
² EXHAUST 0. 660 mm (0. 026 in. ) Tighten the lock
nut to 24 N·m (18 ft. lbs. ) and recheck the valve
lash.
6. Using the crankshaft barring tool, rotate the crankshaft
one revolution (360°) to align the damper
TDC mark to the 12 o'clock position.
7. With the engine in this position, valve lash can be
measured at the remaining rocker arms: INTAKE
3-5-6 / EXHAUST 2-4-6. Use the same method
as above for determining whether adjustment is
necessary, and adjust those that are found to be
outside of the limits.
8. Install the cylinder head cover (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION).
9. Connect the battery negative cables.
genosgarage.com has the barring tool for $42 it does not make any difference in direction of rotation the lifter is setting on the circular portion of the cam, there will not be even one ten thousandth of an inch difference. you do not even need to know where top dead center is or the firing order to perfectly adjust the valves. i learned this trick 30 years ago when we were trying to adjust valves on a engine the harmonic balancer had sliped on. just loosen all and set to speck. in this case 0. 010 and 0. 020 from this point on do not loosen any, just tighten. turn the engine about half turn and check gap, tighten any loose and turn another half turn adjust one more time and if you want turn another half turn and check.
__________________
