Valve Adjust ???
How much are you paying for diesel?
Heading out west
I'd like to adjust the valves on my father in laws 99, can you tell me if the procedure is any different than when I did them on my 05?
Thanks!
tareynolds said:
why did you have to adjust the valves in your 05? this is not a needed adjustment unless the cylinder head has been removed.
Because I wanted too, actually it wasn't a waste of time and we found that most needed to be adjusted.
Just to be clear though, the valves were in tolerance but when they are adjusted right on spec the engine has much less rattle and better throttle response.
IMHO :D
