Engine/Transmission (1994 - 1998) Valve adjust
2nd Gen Non-Engine/Transmission Door Badges
2nd Gen Non-Engine/Transmission Wet Feet
I've done several searches and have not seen this addressed. When adjusting the valves, will I need a crows foot to torque the nut down while I hold the stem w/ the screwdriver? And if so , which size c/f do I need?
Thanks
I just feel somewhere between sloppy loose and stripped threads. Seriously, torque a couple nuts and then check with your box end how much it takes to turn them. you will get the feel of it.
