This is my first post, however I've been reading quite a bit and learned alot so far.
One thing I haven't found in directions or by searching is when you adjust your valve clearances, and you loosen the lock nut, how do you adjust the stud to tighten/loosen the clearances?
I had my valve cover off once (doing the oil breather modification) and checked the clearances (cold motor). Half were right at the upper end of the spec, and half were just outside of the upper spec. I looked at the lock nut but didn't notice anyway to rotate the stud? I was in a hurry and everything was covered with oil, so maybe I missed it?
