valve adjustment
transmission temp guage problem-HELP-
Attention DTT Owners
how many of you out there have adjusted your valves any sooner than the recommended interval. I talked to my dealer today and he said not due until 100,000 miles and it would be out of my pocket expense. my was running yesterday and it sounded a lot louder that it use to and i thought about the valves needing adjustment. any opinions from you folks out there. .
adjusted mine at 50,000, had a few out, around . 006 , after the adj, my ex temp went down 50 deg at low idle, always adj on a cold engine, . 020 ex and . 010 intakes, no setting for injectors, valve cover gasket is reusable... ;)
