Put the engine on #1 compression stroke, use the timing pin to locate this the first time then mark your harmonic balancer. Set the first 3 valves, skip 2 valves, set 2 valves, skip 2 valves, set the next valve.
Rotate engine 360 degrees, until your mark lines up again, now you will be on exhaust stroke of #1 cyl. , compression stroke of #6 cyl.
Skip the first 3 valves, set the next 2 valves, skip the next 2 valves, set the next 2, skip the next valve, set the last 2.
** ** ** ** ** ** pretend 6 cyl. motor
TDC of # 1 cyl. on compression stroke both valves will be loose, both valves on # 6 cyl. will be tight.
First sequence with # 1 cyl on compression
* = set
! = skip
1 2 3 4 5 6
Second sequence rotate engine 360 degrees both valves on #1 cyl. will be tight, both valves on #6 cyl. will be loose.
intake . 010 exhaust . 020
Hope this helps.
Piers, BD engine R&D
