Engine/Transmission (1994 - 1998) Valve and Timing Adjustment
Engine/Transmission (1998.5 - 2002) codes?
2nd Gen Non-Engine/Transmission New Brakes, still pulls to left/right
Monroefiredog1
Hi all,
I was just wondering if anyone knows of the best way to adjust the timing? Do you have to use a timing light? If not what is the procedure? And if your timing is out of adjustment, how much does it affect the running of the eng? Also I think it is about tim e to adjust my valves, does anyone have any imput on this procedure that makes it easier? Thanks in advance for any help. .
96 CTD, 2500, Rebuilt and Boosted Auto transmission, all Stock at present, have got to do the KDP, then Gauges, then the BOMING will Start.....
:D
Look up TSB 18-10-94 Rev A. at //www.dodgeram. info/tsb/1994/18-10-94a.htmr
for instructions on checking and setting the timing. It includes a list of the special tools needed for the job.
My truck is supposed to be set at 12. 5 degrees, when I checked it, it was set at 11.
I raised it to 15 degrees and am satisfied with the results.
