Ok I was searching on here and this cable and came across this.
The tv cable increases pressure while giving more fuel. Also the valve body does to.
My question is why is there pressure at the valve body and the cable? Why can't we just use one or the other?
Another reason I ask is I am tring to now firgure out why going from 2 to 3 shifts way harder than the other gears. I did adjust the cable but made no difference in the way it shifts. It is kinda like it jolts the engine and trans real bad from 2 to 3 but you can feel the other gears on upshift & downshift?
I just don't like the way 2 to 3 jolts my truck.
Do you think it might be to high in valve body pressure?
I do have a ats valve body also.
I am also tring to find a electric pressure sender that works up to 200 psi to hook to my standalone so I can see what pressure I am getting.
I need to get this figured out so I can get more miles on my truck. I just think something will give If I drive it
