I have to torque the valve cover. In searching this topic, I have seen 18 in/lbs once and 18 ft/lbs twice. Which is correct . Ft/lbs seems way too much. I figured just snug with a 3/8 drive socket wrench if nothing else.
At 79000 miles, I probably should have installed a new valve cover gasket after my injector install but I figured if it leaks, I can put a new one on in about 15 minutes. Besides, I want one of those red Cummins ISB covers, I'll get one then. My first injector install went smooth. By the time I got to #6, I could basically to it blindfolded. Took it nice an slow. Everything happened just as spelled out in the directions.
One thing I do know, if you own one of these, ya need a service manual. Where is a good place to pick up the "real thing" for this truck?
