I would assume the specs are the same as the previous 24-valve. As for the wide tolerance range that is probably set up so that you can get the long 150,000 mile valve adjust service interval. Given that it doesn't take a lot of valve lash change to affect driveability and smoothness I agee the range is very wide. On my last truck I adjusted mine twice and always went for . 018" exhaust and . 008" Intake.
I have seen guys with well under 100K with lash almost out of spec and worse yet, cylinders off from each other a lot. I plan to check mine by 50K.
Vaughn
