Valve stem seals
You might get a little oil running down around the valve stems when the engine is shut off but with the turbo supplying air above atmospheric to the intake, it should not be a problem when running. The manual shows stem seals on the 24 valve engine, if it has them and you are going to have the springs off, I would replace them. bg
