When I installed a 383 Stroked Stroker in my 83 Chevy Pick Up, I installed Edelbrock port fuel injection. I was experiencing similar problems with mine. I found that the intake air temperature was getting way too high, especially when traveling at low speeds or after a hot start up. The temps were as high as 230* and would never really come down. I was running a K&N open air filter. I went back to the factory filter housing and snorkel to the radiator support. While I still experience the hot start temperatures, after starting, the air temperature quickly went back to ambient in a matter of seconds. This allowed me to dial up the timing and lean it back out. The second issue I was having, was hot fuel return. With a 20 gallon fuel tank, the fuel in the tank would get to the boiling point. I looked into fuel cooling cans, but decided that the need for ice to keep it cool was not very practical out on the highway towing a trailer. Since the A/C was in use when I had the most problems, I came up with the notion of possibly using it to cool fuel. I wrapped 3/8" copper tubing around the accumulator/dry about 6 times and used stainless hose clamps to keep it tight to the dryer. Then I hooked up the return fuel line to my new cooler. Went for a heavy tow with about a 1/2 tank of gas, it was in the mid 90's, and never experienced any power loss or anything.
