I've had a sticky governor for a few weeks now and finally decided to pull it a part to see whats up. I took the top off and pulled the gov mechanism. Couldn't see any real problem other than clean everything real well. Maybe shmuts on the shaft and slider. My question is this. In the Bosch VE manual it shows 2 ports on the sliding sleeve and a longitudinal passage in the shaft.
On my pump there is only one port on the sliding sleeve and no passages on the shaft. Is this for a different application? Such as pumps with no AFC?
Also what effect does the depth location of the gov shaft have on operation? Deeper vs out.
Anyway cleaned up everything and put it back and it runs good. But I have another truck acting up and was curious about this.
