ve pump adjustment
More Injector Problems?!?!
new member, new project
this may be a stupid Q. . can the pump be adjusted for more performance (without) changing to larger injectors ?... or would this be a waste of time ?
93 w250, 4sp auto, 18. 5 turbo
Hi Cummins250atDpoint,
If I've learned anything around here its 'no question is a stupid one'
Yes, you can improve your performance with pump adjustments without going to larger injectors. Eventually you will need to take that jump. I've read here that the pumps on our 1st gen's are only able to handle so much. There are some really excellent posts on the procedures to follow. I have made use of them extensively and they have been right on the money. Just do some searching for injector pump adjusting, VE pump topics, and such. Search "the archives" for 1st gen trucks. There is also some great info and pics on one of the associated web sites. Here's a couple links to start you out. .
https://www.turbodieselregister.com/ubb//Forum13/HTML/000085.html https://www.turbodieselregister.com/ubb//Forum13/HTML/000084.html https://www.turbodieselregister.com/ubb//Forum13/HTML/000083.html
Your in the right place here to find much of what you need.
Regards, Bush' (still learning too)
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 101,300 Kms (63,000 mi's).
[This message has been edited by BushWakr (edited 03-30-2001). ]
