Also posted on "VE pump leak " I did a search but couldn't find a reference for rear pump leaks. I read "VE pump leak" thread and decided to take a look at the pump on my RV and sure enough it has a leak at the rear of the pump. it seems to come down between the mounting bracket and the rear plate of the pump, hard to ID source, but when the engine is running, it drips off the bottom of the bracket. What seals or gaskets are in the rear of the pump? I have read the other posts and it sounds like the pump should come off but is there a another option for the rear leaks? (I'm Irish so maybe some luck today) Thanks any replies.
__________________
__________________
