Hey guys just got my account set up to finally submit some information that may be helpful. I have been a long time reader
but this is the first time I have had a chance to reply. I don't want to come on as a "know it all" but I feel that some of the recent posts have misinformed you guys and I would like to try and correct you on some specifics of the VE pump. I work in a fuel injection shop on various models of injection pumps, injectors, and turbos. One of them being the Bosch VE (Zexel) pump.
Some recent posts have been about a "modified" fuel pin. I think that you guys are wasting a lot of your time and money trying to make your own pins and what not. The stock fuel pin will allow the pump to come into full fuel at a point about half way down the pin on the shallow side. When we adjust the anaroid on the calibration stand we start at 0 boost with the pin in the stock position and tighten the spring until we have about half of the rated fuel output at full throttle. We then add 10 psi of boost and this is where we would like full fuel to come on by. Turning down the screw or grinding the pin will not allow the pump to gain more fueling. This only controls smoke at little or no boost. The only way to add more fuel is by turning the full load screw which is a very sensitive process without a calibration stand.
Another post I read was about "3K governer springs". The factory spring in your will allow your pump to rev up to around 3500 rpm before it defuels already. By adding a stiffer spring to raise your defueling point you may jeopardize your idling characteristics. Also, to clear up any questions regarding defueling, your pump does not have a defueling curve or anything like that. When your pump reaches the point in which the rpm is set to stop rising, (rev limit)the fuel flow will suddenly stop and then be adjusted to hold the rpm depending upon load on the engine. By raising your rpm you are essentially allowing the same amount of fuel (set by your full load screw) to be added until it hits a higher rpm (set by your high idle screw) and thats when the fuel flow is cut off. Just remember that adding fuel raises rpm and stopping fuel will slow rpm. The governer spring and governer weights work together to hold rpm by adding fuel when the engine slows and stopping fuel when the engine speeds up. A different governer spring will do nothing to help your defueling except allow you to delay it until a higher or lower rpm depending on the strength of the spring.
I would be happy to explain any part of these pumps or anything that has to do with fuel systems on your trucks if you have any questions. After all, I am only on here to help you guys otherwise I would have kept my $35.
