I just saw this on eBay.
Since the auction ends soon - here is the seller's eBay storefront.
The German-English translation is pretty rough, but you can get the idea by reading the description.
Here's my take on things:
Traditional WVO/petroleum-diesel systems require valves, two tanks, heat exchangers and lengthy runs of hose all over the place. With this device, you can get rid of a lot of that AND speed up the engine/coolant warmup times.
Since the WVO/petrol-diesel mix (or dang near straight WVO in warmer ambient temps... ) runs through this thermostatically controlled unit and is heated by a glow plug until the engine warms up and can provide hot coolant (just like the VW TDIs have had for years... ), you allegedly don't need to heat the entire tank of WVO/petrol-diesel mix with a heat exchanger like you would in traditional WVO setups.
Even if you don't run WVO, I could see this device being used in custom or retrofit applications where the OEM setup has a substandard fuel heater and the fuel system becomes prone to gelling. This also has the potential to have a much higher flow-rate than an OEM fuel heater, so it could work for HP applications.
I have no connection to the seller and personally have never run WVO in a diesel engine (yet!
) - so I have no vested interest in promoting this.
Cheers,
Matt
Cheers,
Matt
