I started to get a squeak in reverse, so I installed new u-joints, Spicer 53207x. I marked everything on the drive shaft before taking it apart and put it back together the same way. Now I have a vibration that starts at 55 and smooths out at 75. The truck was running super smooth even with a bad u-joint.
So, I decided to have the shaft balanced. I took the shaft to Jack Lyons Truck Parts in Miami, FL. They said they would balance the shaft at 2000 rpms which I thought was kind of low. They said that I only needed to balance the tube, and that no one balances the whole drive shaft assembly. The shaft had 8 weights on it from factory. They ADDED a 2 oz weight and said it was balanced. Now I have a total of nine weights on the shaft. Anyway, as I'm driving away, the truck starts vibrating at 30 mph. I go back and complain. I asked why they didn't take the weights off in order to start from scratch. They said that if they take the weights off it will leave a hole in the driveshaft. I told them to grind them off and start over. 2 hours later they said I had 3 holes in the shaft and that I needed a new shaft. $240 later, I'm driving away with the new shaft, and at 55 the truck starts vibrating.
I decided to trouble shoot this thing myself by doing the following:
First, I put the transfer case in neutral put the trans in drive and accelerated slowly to 2500 rpms. No vibration, so I know my converter and trans are good.
Second, I jacked up the rear differential removed the rear wheels and accelerated through the gears, the vibration is still there and at the same speed.
Third, I removed the rear brake rotors and accelerated through the gears. Now the vibration is much less but still pretty harsh at 65
Fourth, I put a camera on the thing that looks like a damper on the front slip yoke and watched. It looked pretty smooth
Fifth, I put the camera on the shaft, and it looks kind of smooth but in some spots its hard to tell if it has some run out.
Last, I put the camera on the rear pinion and it looks smooth.
So I think that I have isolated the problem to the drive shaft assembly. Is there a way to balance the entire drive shaft assembly together? Should I just buy a whole new assembly? Your suggestions are greatly appreciated. Thank you in advance.
