I have a vibration generated from the rear for a while. Had annoying front pull to the right. Hit a small whole with rigth front tire, rigth pull stopped. But started pulling to left then added front shimmy like the tire was bouncing. Thought shock was broken. Had scheduled regular service at my new mecahnics(old mechanic is now working there)so I told him to check out front end and rear.
Front right tire belt broke. Rear left tire belt was ready to let go. We had truck jacked up in the rear,(tires off ground)put it in gear, tire started to wobble around 20 mph at the 40 to 45 mph zone it started shake the right rear tire also, matter of fact it shook the whole rear end,the mechanic watching the tire, thought the truck was going to come off the jack. At higher and lower speeds it wobbled alot and you could tell it was out of round.
Tires have just over 40'000, no sign of un- even wear. No I didn't rotate them much,but they never showed any wear problems.
Will see if vibration is still around on new set of tires, until then the Mule stays close to home base. Very close.
Missouri Mule 96 White 4X4 ST club cab,(grey int. ),5 spd, 3. 54 reg dif, 8 ft bed, 1 ft high cheater boards, front and side of bed,Pofile V bug shield,
99 Freight liner FL60 blue Cummins 24v 215 hp, 520 torgue,6 spd 3. 59 no spin rear, 16 ft dry box (white) 19. 5 low profile tires,Weight 11,000, gvw 23000, 11 to 12 mpg
Bill Thomas (Wild Bill)
