Guys this has been driving me nuts for years. See info in post link below. Then read latest finding below the link.
https://www.turbodieselregister.com...2062-would-you-put-these-back-your-truck.html
With axels out, on stands, started up, put in neutral, then drive, gradually ran speed up to feeling slight vibration (45 - 50) then increased speed to 60 - 70, frequency of vibration increased. Now the vibration was not as noticable as when the axels were in, but it's the "same" frequency but not as pronounced - less rotating mass - make sense?
I had my daughter get behind wheel and do as I had - in gear at speed mentioned above - I put hand on carrier bearing, vibe present, moved forward and placed hand on trans tail shaft, vibe present a bit more noticable. Shut down, put in park, started up and ran engine rpm up to 1600-1700, no vibes from trans, but still noticable and at same frequency. Moved to front of engine put hand on front of oil pan - BINGO - I hope, the vibe was there at the same frequency just barely noticable.
So, I'm thinking the balancer is the culprit? I had this happen on a 289 Ford, going down the highway the whole car felt like it was going to come apart, after the balancer was replaced smooth as silk. I feel like an idiot for not looking at this first - having experienced this many years back with the 289, but it wasn't making sense with the truck as other factors were looking more promising as being the problem.
Now, before I spend ?$$$? on a fluid dampner, how to check the exisiting balancer to "make sure" it is the problem? I've thrown so much $$$ at this thing trying to smooth it out my wife is ready to kill me :-{}. So, I'm hopeful someone can shed some light on:
1-if the balancer could be the problem - to me it seems to make sense - less rotating mass (axels out, wheels off) less noticable vibes.
2-how to "make sure" the balancer is the problem - how to inspect it.
Man if this is it I'm going to do the Snoopy dance. :-laf
