I've always said two heads are better than one. So let me put this one to all my good friends in TDR. I converted my 96 three quarter ton to duallys using a chassis cab DANA 80 and the one ton springs. I also converted to five speed from auto. Needless to say the drive shafts had to be modified. / Having said that, everything is fine when not towing. No rumbles and no shaking or rattling. Now when I hitch up to my fifth wheel (14,000 lbs) I get the following; Take off in first, shift to second and all is well, but when I shift to third i get this jerking back and forth like the differential is torquing back and forth. If I shower down on the power it quits and I am able to get above it and all is fine in fourth and fifth gears. I kind of suspect weak psrings and the differential is torquing. What do you all think?
Jim
96, 3/4 ton 230 HP, converted to 1 ton.
Jim
