I bought new tires and had a vibration at hwy. speed, it turned out to be bad balance job on the right rear. If you don't have limited slip differential you can check the rears by jacking up one side at a time and spinning with the engine. I think you only go up to half speed as the one tire turns faster because of the spider gears in the diff. bg
