Back to you Gino....
GCecchetto said:
David;
I'm very interested in the tires you have if they were revulcanized, the price is right! How do they handle on the road? Do they wander, are they noisy? Where did you get them? Do you by chance know the name of the company that did the retread?
Thanks
Gino
Yes, they're re-vulcanized. You can barely tell they're not factory new.
They handle very nice, solid & frim, but not harsh unless I forget to 'air down' after towing. No wandering at all. I've already hauled 20,000 # gross weight in my cargo gooseneck trailer to Texas twice - solid & safe !
I told 'em I wanted very good mud & snow handling, w/o noisy tread. They showed me the XDC 22 tires - glad I got them. They have a nice 'sing' at 65 mph but are not 'noisy'.
Picture here:
http://www.michelintruck.com/michel...read/Premoldsbyposition.jsp?position=D#XDC 22
EricBu from SLC, UT said he got the XDE m+s design -just below mine on the page- and it worked great for him.
I recommend for any 19. 5 you choose, reman or new, to have them 'matched' with that Hunter Road Force balancer procedure. If your America's tire that sold you the rims has that system, you might consider buying liftime balancing & rotation along with - our local America's tire did it for $ 110.
They balanced up nicely - very smooth at all speeds, except a slight resonance at around 45 mph, then it's gone. [I read the thread on the 'Centramatics' balancers that mount between the rim & hub the idea is to keep you balanced at all times- sounds interesting but I don't think I truly need 'em. ]
You have some choice on tread patterns as you can see from the Michelin Factory reman page. Whether a particular local-to-you commercial truck center will have the exact size you decide on, in the exact tread pattern you want is yet to be seen
I suspect if you have a worn out set of 4 good 19. 5's, and can wait, they'll put any available tread pattern you choose on them.
I had no casings, so they gave me 4 that were part of the inventory for a local tow truck firm's trade ins - they just chaged me about $ 30-40 ea for a 'casing charge' making $ 125 total cost per tire. That means if you have casings they only charge about $ 85 labor to retread your tires - ha pocket change !
The Michelin site shows a flash program on their process so you can see how they make them. All that is at:
http://www.michelintruck.com/michelintruck/productguide/retread/Retread.jsp
I got my tires from TCI tire centers in El Cajon (San Diego) - they're a nationwide commercial tire chain, you can search to see if there is one in your area:
http://www.tirecenters.com/products/commercialprods.cfm
For your lighter loads, you have the option of going with a LR "F" still having 3500 # load ea, and because it should weigh less, you'll have less rotational mass. Not to mention your new rims are aluminum, not steel like mine. With the run-up in fuel prices, every bit helps.
Hope all these musings are of help to you Gino.
Keep us appraised what you decide, and if you can post pics of your truck & rims, will you ?
Thanks, David B.
