Engine/Transmission (1998.5 - 2002) " Void" sticker
What is the red/orange "void" sticker on the drivers side of the engine near the injector pump- I have no mods other than BHAF- is this factory or did dealer do it because I have a different intake- they didn't tell me- What gives???
There are commonly two void stickers on the newer trucks. One is on the plug that plugs into the injection pump and the other on the plug that goes into the ECM. Both are in place to detect tampering with the truck. So if you decide to pulg in a BD plug-n-play box you have to tear off the void sticker and the dealer will be able to tell.
Of course now some of the box makers send a new void sticker with the box so when you take if off you can put the new one on, and some members have pulled the sticker off without tearing it and reapplied it.
Hope that clears it up.
That's a sticker that is factory installed on all Dodges after 2000. They put it on to discourage pluging in a power box (BD Plug n Power) to increase horse power.
Re: Edge EZ
Originally posted by mimprevento
Does this apply to the Edges as well?????? Thanks for the help
No, you plug into the data connector when using the EZ... . so its a different plug/location then the void sticker on the injection pump.
