volant air intake ?'s
transfer case upgrade
Searched for downpipe info but...
ToolManTimTaylor had one at one time. Not sure if he is still using it but you may shoot him a PM. I know he can send some pics of the install. :)
Still Have it and Kinda Bombed it too. What I did was take HVAC flashing / sealing metal tape and wrapped the inlet hose iwth it. Then took the doublewall aluminium sided "Bubble wrap" and panneled the box with it. THEN I took a thermocouple for my FLUkE meeter and found that even the inside airbox temps were now ambient with the outside air. I will see if that holds true when the temps get into the 90's this summer to make the ultimate test. They are a good looking unit indeed! They also have the option to draw additional air thru the cowl area much like the Scotty system that pioneered that very concept. I just aordered a replacement filter for it as I must have damaged my origional one cleaning it a lil too heavily.
I have a Volant too. Real nice looking box and an easy install. You will probably need to trim the intake tube a little. Put the hole in the cowl and you can realy hear the turbo.
