Yesterday when starting my '01 HO 6speed, it cranked a half-second before firing, so I put a volt meter on (when not running) and got only 12. 51 volts.
Today I took it to a battery shop and when they had their machine hooked up and engine ideling(after a 55 mile drive), it would be showing about 14+ volts (it moved around a little), and about 50 amps; then suddenly and for about a second, the volts would drop to around 12. 3 and the amps would jump to around 150 amps. then back to as it was before for a few seconds then back again.
The heater was on, so I turned that off thinking maybe it was the air cond. condensor cycling, and it seemed to quit. Later it seemed to do that change with or without the heater or defrost running. Then for a while it did not ???
One battery had a bad cell so we installed two new batteries and the situation repeated as before.
The temperature was in the low 60s and it was a damp day with intermitant rain.
Ideas?
Could this be the air intake heaters cycling? and if so could the cool day with several minutes of ideling let the engine cool enough to cause that , even though I had driven 55 miles at highway speeds?
Is it more likly a defective AIT sensor??
Something else??
I would appreciate ideas------other than go to the dealer.
Thanks
Vaughn
Ideas?
Something else??
Thanks
Vaughn
