I started up the road yesterday. Just after I got on the freeway the check gauges light and chime came on. When I looked at the gauges I saw the voltage gauge had gone to zero. My first thought was crap, the alternator is toast. So, I took the first exit and went home. When I got home before I shut the engine off, I put a voltage meter across one of the batteries and got 14 plus volts. So, the alternator is working. I shut the engine off and measured across the battery and got about 13.5 volts which is what I expected. So, I put the key in the run position and the needle on the gauge moved up to about 12 volts (I guess). So I restarted the truck and 30 seconds to a minute later the needle was back where it should be at about 14 plus volts. So, I went on my little trip north about 70 miles with no more problems. I came back again this morning with no problems.
Any idea what could cause that ? If it was a computer glich, can I expect it to happen again ?
Oh, I may have heard a slight pop just before the needle went to zero, but Im not sure of that. I also may have smelled a slight burning plastic smell after driving north yesterday, but not enough to be sure. I looked under the dash and did not see anything that looked burned and I didnt feel any excess heat.
