Hi there,
I have noticed over the past several months that when I start the truck ('06 5. 9 TD) after a period of non-use that the voltage needle will rise beyond the middle "14" approximately 1/2 way to the upper end of the normal range. Soon there will be an audible click and the needle will fall below the "14" along with the dimming of lights. Soon another click will be heard and the process repeats itself for 3 - 4 repetitions and then the needle settles above the "14" and will stay this way. If the truck is shut off for more than 5 minutes, the whole thing repeats itself. As time has gone by the swing below the "14" is getting deeper almost to the lower level of the range. So does this mean the voltage regulator, which I understand is part of the alternator, is going out?
