Engine/Transmission (1998.5 - 2002) voltage regulator question
Engine/Transmission (1994 - 1998) Grid Heater
2nd Gen Non-Engine/Transmission Limite Slip or Locker?
I am getting an arc in the voltage from the PDC. I am wonder what is the voltage regulation circuity in the PCM. What tests can be done to see if it is bad???
If the P-1693 code comes up, is the companion code that should come up ( ECM/PCM ) not coming up is that the one that is bad ????
