I have done most or all to get rid of the skip or hesitation what ever you want to call it. I have not brought the truck to the dealer.
The truck's engine skips (4 times) at 1800-2200 RPM'S W. O. T. after 2300 the skip goes away and runs fine to 3200. But I have lost a lot of time.
When I slap the pedal to the floor this thing happens, if I do this slow I do not notice it hardly at all. I put on (3) new Lift Pumps. I change all the lines to 3/8, I went with aeroquip steel braded lines and fittings. It did not change a thing I still had the problem.
So I put on the two fuel pumps 1-15lb 100gph and 1-7lb 100gph pusher, no change the VP-44 will not handle W. O. T. Slap down.
The build date is 10-00 I think this is a KEY to what went on. I can also do this with the box off. I put it in drive and power break it will happen.
Does this Happen to YOU????????????????
Got to go work on the new Trans input shaft. Talk to you latter. Steven
